The heat transfer depends on the temperature difference. I hope you have initialized the inside temperature correctly. Also, make sure to apply appropriate boundary condition (coupled) between the inside air zone and the solid wall zone.
"but I'm not getting the desired result."
Can you please explain how your results are deviating from expectations.
Thanks!
Nikhil
