December 9, 2022 at 3:30 pm
Hi Erik and Ankush,
Thank you very much for your answers. I've tried to follow your advice but I'm stuck, I'm not familiar with working with snippets or running scripts inside mechanichal so I may be missing something.
I've written this APDL script that generates my desired geometry:
FINISH
/CLEAR ! clear database
/PREP7 ! enters the preprocessor
! MATERIAL PROPERTIES
YNGMOD = 2e11 ! Young's modulus
PCOEF = 0.27 ! Poisson coefficient
MDENS = 7850 ! Material density
! SECTION DIMENSIONS
! CTUBE1
Intrad1 = 6470
Extrad1 = 6500
!CTUBE2
Intrad2 = 9370
Extrad2 = 9400
! Element types
ET,1,BEAM189 ! create 3-node beam element
ET,2,SHELL281
!define material
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,YNGMOD ! Young's modulus
MPDATA,PRXY,1,,PCOEF ! poisson coef.
MPDATA,DENS,1,,MDENS ! Density. For considering own weight
! Keypoints Definition
K,1,0,0,0
K,2,0,0,-4000
K,3,0,0,-12000
K,4,0,0,-120000
K,5,0,0,10000
SECTYPE,1,BEAM,CTUBE,CT,0
SECOFFSET, CENT ! Origin of section located at CoG of section
SECDATA,Intrad1,Extrad1,64,0,0,0,0,0,0,0,0,0 ! Variables of section
LSTR,1,2! Straight line connecting each KP
LSEL, , , , 1 ! Selecting the generated line
LATT,1, ,1, , , ,1 ! Assigning the variable section, element type and material properties to line
LESIZE,1,400 , ,, , , , ,1 ! Size of Mesh
LMESH, 1 ! Line Meshing
SECTYPE,2,BEAM,CTUBE,CT,0
SECDATA,Intrad2,Extrad2,64,0,0,0,0,0,0,0,0,0 ! Variables of section
LSTR,3,4! Straight line connecting each KP
LSEL, , , , 2 ! Selecting the generated line
LATT,1, ,1, , , ,2 ! Assigning the variable section, element type and material properties to line
LESIZE,2,800 , ,, , , , ,1 ! Size of Mesh
LMESH, 2 ! Line Meshing
LSTR,2,3! Straight line connecting each KP
SECTYPE,3,TAPER, ,TC ! We define a taper to generate a variable section. Tower's transition piece.
SECDATA, 1 ,0,0,-4000, ! Initial base of variable section
SECDATA, 2,0,0,-12000,
LSEL, , , , 3 ! Selecting the generated line
LATT,1, ,1, , , ,3 ! Assigning the variable section, element type and material properties to line
LESIZE,3,400 , ,, , , , ,1 ! Size of Mesh
LMESH, 3 ! Line Meshing
! Upper section
K,5,0,0,10000
LSTR,1,5! Straight line connecting each KP
LSEL, , , , 4 ! Selecting the generated line
LESIZE,4,1000 , ,, , , , ,1 ! Size of Mesh
LMESH, 4 ! Line Meshing
/ESHAPE,1.0
And the result is
Actually, the part of the code I would like to implement is this, where I define a tapered section from the sections already defined above for the rest of the line bodies:
What I've tried so far:
- Use design modeler to build the line bodies and the two CTUBES, transfer the geometry to a mechanichal model (tried to implement the snippet by inserting an apdl command to the desired line body, but it doesn't make any change) and then to the hydrodynamic diffraction module.
- Archive the apdl model and load it in workbench using the external model option, but workbench is reading the the tapered section as a constant CTUBE equal to the start of the tapered section
- Use the spaceclaim 'extract' option under 'prepare' tab to extract the tapered section, but the hydrodynamic difraction doesn't like it
I would really apreciate if you could help me implementing the code inside mechanichal. Thank you very much for your help.
Best regards,
Javier
