December 11, 2022 at 8:09 am
Thank you so much!!
I didn't use the MAT command :( Now I write MAT,3 in my file and it works.
When it is sliding, I output the data of Fsz(ETAB,lab,nmisc,3), it does equals to MUFn which is consistent with the fritional contact behavior.
But I wanna make the Fsz equals to tangential stiffness times sliding distance which is a changing force.
Therefore, the fritional contact behavior can not satify my need.
I tried to write my own contact interaction(USERINTER) but there is no example for reference. I have trouble writing this.
Do you have the USERINTER example? or I can just modify the contact behavior.
Hope you coule give me some advice.
(I'm a beginner and I don't speak English. I apologize in advance if I have caused you trouble :()
