Use Frictional Contact. Edit the Pinball Radius and type in a distance of 4 mm to make sure the contact is detected as Near Open. You can check that by inserting a Contact Tool under the Connections folder and Generating the Initial Contact Status.
New Post - Reply To: what contact should I use
