December 13, 2022 at 9:20 am
Thank you very much for your reply.
I'm so sorry to hear that. Because I think the data I have is convenient for nodal displacement. It would not be appropriate to calculate a single displacement on the entire surface from the data at the points I have.
Except for the nodal displacement constraint, I gave the model fixed support and frictionless support from the bottom. I defined the material parameter myself and defined the density, young modulus, and Poisson ratio values.
Best regards ...
