Hi d-tve21jan004,
You can follow the below steps if you want to connect your Matlab circuit to the Maxwell excitations.
1. Change all the excitations in Maxwell to external
2. Right-click on “Excitations”, then select “Setup Co-Simulation with Simulink...”.
3. Click “Import Circuit...” and locate .slx file.
4. Click OK to finish the setup and run the simulation.
Refer to Matlab optimizer section in the Maxwell Help for more details on compatibility and optimization
Navya
