Please reply with an image of the geometry in Mechanical. If you select Static Structural in the Outline, it will label the loads and boundary conditions so we can see which face you applied the fixed support, the frictionless support and the nodal displacement. Is the Nodal Displacement on the same surface as the Frictionless Support?
