December 13, 2022 at 3:08 pm
Thank you Rahul.
I will try tabular data but I don't know how to do. Do you have any suggestions (lesson, video etc.)?
Mr. Peter, I will share the images of my model.
A and B are the nodal displacement, B is the frictionless support and D is the fixed support. There is 9 part. I defined bonded contact to the horizontal surfaces and to no separation contact to the vertical surfaces (I'll also try the frictional, and frictionless contact until the test nodes RMS that is calculated by using known and model result displacement values is minimum).
Best regards...
