Ah, okay, now I understand.
You can't use nodal displacements to pull single nodes on the Earth surface to match GPS measurements of the Earth surface.
You need to create a model of the Earth's crust that applies the pressure from below and from the sides to cause tectonic movement and adjust those boundary conditions until they have an acceptable match to the GPS measurements.
