December 13, 2022 at 6:36 pm
You are right. However I think that the result will be more reliable if I can perform the analysis by using some of the GPS data as boundary conditions and some as test data. The applied pressure can change according to the entered material parameter or contact type. The material parameters I use are the values obtained through various approaches and assumptions so I also aimed to test the material parameter in analysis.
