A continious increase in file buffer cache results in performance loss. This might happen over a period of time because of I/O activitiy. Some OS do not free up cache even if Anys Fluent session has been closed. More details to be found in the Fluent User's Guide.
Now In the Fluent launcher you can put the -cflush flag in the "Fluent Root Path" field. This is visible when you select "Show More Options" in the Fluent Launcher. Starting from command line you can just use the flag -cflush.
