Hi
I can not help with that, but what I would suggest is that you look up and understand the commands I posted and use them as needed – aslo reading up on apdl and the apdl command reference (e.g., MPCHG command etc) is good if you want to use that in the future (apdl commands in mechanical).
Also you can just have two different models (one linear and the other nonlin.) - export results to excel from both, and then combine them as you want – all the best
Erik
