Are you trying to deform something or move a rigid body? More information will help. Otherwise, check whatever triggers the motion is triggered and that the UDF is correctly hooked in: the latter is covered in the documentation.
New Post - Reply To: Dynamic Mesh UDF for 3D case using DEFINE_GRID_MOTION
