It is possible that there was some issue with getting the license, mesh or solver error which might causing the delay in starting. Please the window console which shows you the solution progress to check for this. Otherwise, check the uns.out file in the project directory and check the lines at the end of this text file for any errors. Please fix those errors and try again.
