Victoria Kurushina
Is the open circuit voltage the same parameter as the total system voltage (when Converge to Specific Voltage is ticked)? If not, what is the difference? Does the electic potential at wall_voltage_tap have to be higher than the total system voltage, as you mentioned before?
