I suspect you'd don't need to mesh inside the drone either. For most drag calculations we only care about the "outside" air flow. That'll save you mesh and remove the interface zones that are probably where you went wrong.
New Post - Reply To: I can’t define setup because my design doesn’t show up in setup section in CFD
