RM
Hi ,
That is the way to define the coupling interfaces. Are you using different geometry for fluent and mechanical? It will be helpful if you use single CAD file containing  both fluid and solid regions. And while meshing, suppress the fluid region when meshing solid in Mechanical and suppress solid region when meshing Fluid region.
