Hi Toms Kaidalovs, you use ANSYS ensight to render the animation via ray trace options and material applications, havign to do the blender is tricky as you need to import the adres to vtk, you can use ensight to generate .case which can be imported to to paraview from here you nedd to generate .obj for all the timestrps from paraview with some addons , check the link
and this apply after you import .case file into paraview
Cheers, Ram
