Arindam Singha
Hi srwheat
I am facing the same problem. I am trying to run fluent in a cluster through Slurm. When I launch the job, I get the following error. It is the same error you have faced. Can you please let me know how did you solve it?
Thanks
Build Time: May 27 2022 08:43:47 EDT  Build Id: 10212
Connected License Server List: 1055@172.16.1.22
Host spawning Node 0 on machine "n001.cluster.pssclabs.com" (unix).
/opt/ansys_inc/v222/fluent/fluent22.2.0/bin/fluent -r22.2.0 3ddp -flux -node -alnamd64 -t4 -pshmem -mpi=openmpi -ssh -mport 172.16.32.1:172.16.32.1:40169:0
Starting fixfiledes /opt/ansys_inc/v222/fluent/fluent22.2.0/multiport/mpi/lnamd64/openmpi/bin/mpirun --map-by numa --mca btl self,vader,tcp --mca pml ^ucx --mca btl_sm_use_knem 0 --prefix /opt/ansys_inc/v222/fluent/fluent22.2.0/multiport/mpi/lnamd64/openmpi -x LD_LIBRARY_PATH --np 4 --host n001.cluster.pssclabs.com:4 /opt/ansys_inc/v222/fluent/fluent22.2.0/lnamd64/3ddp_node/fluent_mpi.22.2.0 node -mpiw openmpi -pic shmem -mport 172.16.32.1:172.16.32.1:40169:0
ID    Hostname              Core  O.S.      PID        Vendor
n0-3  n001.cluster.pssclab  4/64  Linux-64  5335-5338  AMD EPYC 7513 32-Core
host  n001.cluster.pssclab        Linux-64  5088       AMD EPYC 7513 32-Core
MPI Option Selected: openmpi
Selected system interconnect: shared-memory
Cleanup script file is /net/clusterhn.cluster.pssclabs.com/home/asingha/slurmtest/cleanup-fluent-n001.cluster.pssclabs.com-5088.sh
terminate called after throwing an instance of 'std::runtime_error'
  what():  locale::facet::_S_create_c_locale name not valid
Stack backtrace generated for process id 4882 on signal 6 :
1000000: fluent() [0x7a5969]
1000000: /usr/lib/x86_64-linux-gnu/libc.so.6(+0x43090) [0x15302303f090]
1000000: /usr/lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb) [0x15302303f00b]
1000000: /usr/lib/x86_64-linux-gnu/libc.so.6(abort+0x12b) [0x15302301e859]
1000000: /opt/ansys_inc/v222/fluent/fluent22.2.0/lnamd64/syslib/libstdc++.so.6(+0x8b833) [0x1530233e3833]
1000000: /opt/ansys_inc/v222/fluent/fluent22.2.0/lnamd64/syslib/libstdc++.so.6(+0x919a6) [0x1530233e99a6]
1000000: /opt/ansys_inc/v222/fluent/fluent22.2.0/lnamd64/syslib/libstdc++.so.6(+0x919e1) [0x1530233e99e1]
1000000: /opt/ansys_inc/v222/fluent/fluent22.2.0/lnamd64/syslib/libstdc++.so.6(+0x91c13) [0x1530233e9c13]
1000000: /opt/ansys_inc/v222/fluent/fluent22.2.0/lnamd64/syslib/libstdc++.so.6(+0x8d767) [0x1530233e5767]
1000000: /opt/ansys_inc/v222/fluent/fluent22.2.0/lnamd64/syslib/libstdc++.so.6(+0xb2574) [0x15302340a574]
1000000: /opt/ansys_inc/v222/fluent/fluent22.2.0/lnamd64/syslib/libstdc++.so.6(_ZNSt6locale5_ImplC2EPKcm+0x4c) [0x1530233fcf7c]
1000000: /opt/ansys_inc/v222/fluent/fluent22.2.0/lnamd64/syslib/libstdc++.so.6(_ZNSt6localeC1EPKc+0x4b2) [0x1530233fde32]
1000000: /opt/ansys_inc/v222/fluent/lib/lnamd64/libApipWrapper.so(+0xf0c73) [0x1530237cbc73]
1000000: /opt/ansys_inc/v222/fluent/lib/lnamd64/libApipWrapper.so(_ZN5Ansys10ApipHelper13GetInstallDirEPKw+0x591) [0x153023762c41]
1000000: /opt/ansys_inc/v222/fluent/lib/lnamd64/libApipWrapper.so(_ZN5Ansys17ApipConfiguration20initializeForVersionEPKw+0x1d) [0x15302377092d]
Please include this information with any bug report you file on this issue!
No error handler available
Error: Cortex received a fatal signal (unrecognized signal).
Error Object: ()
