December 19, 2022 at 6:05 pm
Are you sure this is the command you are using? There should not be two i= arguments on the command line.
Here is the command line I use to run SMP on Linux:
/data2/rgenest/lsdyna/ls-dyna_smp_d_R13_0_0_x64_centos610_ifort190/ls-dyna_smp_d_R13_0_0_x64_centos610_ifort190 i=/data2/rgenest/runs/Test/input.k ncpu=-4 memory=20m
Try to specify the complete path of the LS-DYNA solver as in the command line above.
Which LS-DYNA solver are you using when the run is successful? Have a look at the LS-DYNA banner in the messag file:
Reno.
