"lsdyna" is the default ls-dyna executable filename created from "make", as I am using user subroutines, and I run ls-dyna in the same (working) directory as "lsdyna" is created. Again, the command that works is "lsdyna i=job.k"
New Post - Reply To: can’t run ls-dyna in background on Linux
