thank you for your reply. So I basically calculate the pressure manually by calculating the total contact force and using the contact area. Is there also a way to use user defined results (e.g. with the word "PRESSURE")?
Thanky, Luisa
New Post - Reply To: How to output the contact pressure of an impact situation in ansys explicit?
