December 20, 2022 at 11:31 am
Hi Manish,
thank you for the suggestions,
i have tried to supress the imported load and create a new force load onto the top face of the workpiece with 500N and the solution worked. But i dont know how could the imported load be a problem, in the summary it states number of source & target& nodes mapped all have the same number and the number of nodes not mapped : 0.
I tried also to change the material to structural steel and it worked also.
I tried to use contacts instead of shared topology and it didnt work.
I setup the initiap substep=200, min substep=25, max substep=10000; Large deflection = On;
Here is some data of the alu that i use:
