December 20, 2022 at 3:34 pm
Hi George,
I went into the directory you listed, and the license file is actually one directory up in the 'licensing' folder instead of license_files folder. That file also only has 2 lines in it: SERVER= and ANSYSLI_SERVERS=
After each line is port@licenseurl and that's it.
For the VENDOR ansyslmd PORT=1056 line you put, would that be in this format instead: VENDOR_ansyslmd_PORT=1056 if I add it to the license file?
Thank you for the input so far though.
