What modification did you do for the script andsimulation file?
Since you did not specify which file, I just tested the Step 5, withought changing anything:
When you have more voltage points, make sure the raw data has that voltage. Otherwise, the data will be interpolated, and errors can happen.
I also tested positive voltage and they worked well. Then I tested 1.5,2.5 and 3.5V and the result has no positive result.
Please test/check the individual voltage and see if the data has gain.
