You must have some geometric imperfection in the geometry, or an eccentric load or a lateral load to cause the column to buckle. You can use an Eigenvalue buckling solution to change the geometry before you run the Static Structural model, or you can draw the imperfect geometry in CAD, or you can apply a lateral load in step 1 then apply a compressive load in step 2.
