Which Ansys C compiler? Are you working on Windows? You can there user Visual Studion. On Linux standard compiler is GCC so not Ansys C compiler.
If you are using a new Ansys Fluent version and even if you are running on single node that is still parallel and you will have HOST and NODE0 so both will try to write to a file.
