December 22, 2022 at 1:19 pm
Dear Praneeth,
Thank you for your response. To answer your questions;
- Yes, the lens is using a 10x Lambda design, so at 77 GHz the lens is 38.9 mm away from the antenna.
- The material properties are shown in this image.
3. No, I believe the faceting is a result of importing the mesh from an external modeling program.
4. Yes, I believe so. As part of the process of importing the antenna I enabled model blockage (as shown in the screen shot)
for the surface on which the antenna is mounted.
