December 22, 2022 at 6:04 pm
I use recorded script but i modifided it for create a wizard.
My code :
import System
import clr
import sys
import os
import math
import zipimport
import __builtin__
import commands
import random
'SpaceClaim': , ,
'Commands': ,
'System': ,
clr.AddReference("SpaceClaim.Api.V22")
clr.AddReference("SpaceClaim.Api.V22.Scripting")
#clr.AddReference("AnsysSCPlugin.22.2")
#from SpaceClaim.Api.V22 import Geometry
#from SpaceClaim.Api.V22.Scripting import Commands,Helpers,Selection
#from AnsysSCPlugin import *
from SpaceClaim.Api.V22 import *
from SpaceClaim.Api.V22.Scripting import *
from System import *
part = None
def oninit(context):
return
def GenerateBF(step):
global part
win = Window.ActiveWindow
context = win.ActiveContext
part = context.ActivePart
if part==None:
part = context.ActivePart.Master
body = part.Bodies
#verifier le measurehelper
#--------- selection--------------
ExtAPI.Log.WriteWarning("TENTATIVE 2")
#body = GetRootPart().Bodies[0]
#se = Selection.Create(body)
#se = Selection.Create(GetRootPart().Bodies[0])
#se = PowerSelection.Bodies.AllSolidBodies(PowerSelectOptions(False))
#se = Selection.SelectAll()
#se = SpaceClaim.Api.V22.Scripting.Selection.ISelection.FilterByVisible
#---------------------------------- attempt 1
#X = Direction.DirX
#Y = Direction.DirY
#Z = Direction.DirZ
#XMIN = se.GetExtremePoint(-X,Y,Z)
#XMAX =se.GetExtremePoint(X,Y,Z)
#YMIN = se.GetExtremePoint(-Y,Z,X)
#YMAX =se.GetExtremePoint(Y,Z,X)
#ZMIN = se.GetExtremePoint(-Z,X,Y)
#ZMAX =se.GetExtremePoint(Z,X,Y)
#xOverall = abs(XMAX[0]-XMIN[0])
#yOverall = abs(YMAX[1]-YMIN[1])
#zOverall = abs(ZMAX[2]-ZMIN[2])
#----------------------------------- attempt 2
#bb = Selection.Create(GetRootPart().Bodies[0])
#MAX = bb.BoundingBox.MaxCorner
##MIN = bb.BoundingBox.MinCorner
#xOverall = abs(MAX[0]-MIN[0])
#yOverall = abs(MAX[1]-MIN[1])
#zOverall = abs(MAX[2]-MIN[2])
#-------------------------------------attempt 3
#centre = SpaceClaim.Api.V22.Scripting.Helpers.MeasureHelper.GetCenterOfMass(se)
#rX = Direction.DirX
#ms = MeasureHelper.BodyExtrema(se).X
#bb = SpaceClaim.Api.V22.Scripting.Selection.ISelection.AddToActive(Selection.Create(GetRootPart().Bodies[0]))
#rr = SpaceClaim.Api.V22.Scripting.Helpers.MeasureHelper()
#cvd=rr.BodyExtrema(bb)
selection = SpaceClaim.Api.V22.Scripting.Selection.BodySelection.Create(GetRootPart().Bodies[0])
#selection = SpaceClaim.Api.V22.Scripting.Selection.ISelection.SetActive(SpaceClaim.Api.V22.Scripting.Selection.ISelection)
xOverall = SpaceClaim.Api.V22.Scripting.Helpers.MeasureHelper.BodyExtrema(selection).X
#sele = PartSelection.Create(GetRootPart())
#sele = GetRootPart().Bodies[0]
part = None
There are error on "xOverall=SpaceClaim.Api.V22.Scripting.Helpers.MeasureHelper.BodyExtrema(selection).X"
"selection" is not right, we need an "ISelection" type and we have the "Selection" type. I can't use the "MeasureHelper.BodyExtrema()" function, when I use it in Wizard.
Thank you
