Under the Connections folder, insert a Contact Tool then right click on it and Generate Initial Contact Status. You need to see the contact is Near Open. If it is Far Open, you need to increase the size of the Pinball Radius.
I was expecting the contact between the cushion and face would be Frictional.
Also, it will save some time if you move the mask until it is just touching the face instead of having a large gap.
