For the two contacts that have a gap, edit the contact definition and Add Offset, No Ramping and type in a number that is twice the size of the gap then Generate Initial Contact Status. You should see more contacts closed. If you don't get 1000 elements closed, increase the Offset some more.
I can't recall if a positive offset increases the gap or decreases the gap. Maybe you will need to use a negative number.
