The DHCP Option set for the VPC in which the HPC resource will be deployed is not configured and adding a domain for the VM may have failed. Please check the configuration of the DHCP option set.
If you have not found a problem with your setup, please contact support.
New Post - Reply To: “Unable to list vm sizes” alarm appears and VM is not available for connection
