Thank you for your reply! So I outputted both the surface and volume mass-weighted average temperatures and for some reason the former outputs 0 K and the latter around 400 K. Shouldn't they be the same value for a 2D simulation?
Furthermore, to output average HTC, do I first run the calculation with the reference values computed from inlet, and output the mass-weighted average temp in the console, then input this value into the 'reference temp' part under 'reference values' (without changing anything else), and then compute the average HTC using this reference temp? (baring in mind that I don't need to rerun the calculation when changing the reference temp value).
Thanks a million. I'm not really allowed to post any images online, sorry about this
