The Total Deformation plot is to look at the shape only and the magnitude is arbitrary with a maximum of 1.
A temperature load is applied in Buckling so if the Environment Temperature was 20 C, which is no load, then the temperature load is an increase of 80 C and you multiply that by 0.0432 to get a load of a 3.4 C increase or a temperature of 23.4 C with all the other loads applied in the Static Structural.
New Post - Reply To: Pipeline Buckling Analysis
