December 23, 2022 at 10:16 pm
1) Thank-you for the comment on the mesh.
2) The properties for high pressure air were defined only in the patching window as follows:
and the operating conditions are as follows:
3) The turbulence model used is k-omega:
and the time step is as follows:
I also tried running it with the following fixed time step and the results look the same:
4) VOF Selection:
Your help is much appreciated, thank you!
