December 26, 2022 at 9:44 am
Hi Peter,
Thanks for the reply.
- Noted on that. Hence the buckling analysis in Ansys would only be able to study the shape but not the actual amplitude of the buckling?
- Got the idea of how the multiplier works, so the critical buckling load would be the total load I applied in the static structural and at 23.4°C, is that correct? Does the mutiplier shown in -ve suggests not applicable solution? Would like to do a comparison between actual buckling load from simulation and analytical solution.
- Yes I noticed it did came out as a warning and the amplitude of the pipe buckling came out differently where it is maximum at the starting and end point of the pipe. I have fixed the total deplacement at the starting and end of pipe and the result makes more sense.
