You need to select the nodes on the surface prior to the esurf, not elements. A possible way would be to use a named selection for the faces you want to apply the surf152 elements to. Then cmsel,s,named_selection would select those nodes prior to the esurf command. The radiation capability in Mechanical would seem to be a better way to model radiation though.
