Hello Jose,
Can you check the cfd_solve_level2 license increment present in your license file? If yes, then open 'Ansys Client Licensing Settings' as administrator (Right click and run as admin) check the correct license server name mentioned.
Or you can check in ansyslmd.ini file path is : "C:\Program Files\ANSYS Inc\Shared Files\Licensing\ansyslmd.ini".
Let me know if that works.
Thank you.
