When you combine high pressure, which is compressible, with another part, water, which is incompressible, the high pressure dissipates almost instantly because in the incompressible area, the speed of the pressure wave becomes infinite.
I suggest choosing an ideal gas based on density to modeling both areas as compressible.
Thanks
