one of the error message tells that element 19699 from upper body is having high distortion. Will you please check how is mesh over there. My initial suspect is either material modelling/ meshing issue (Upper body part).
Thanks
New Post - Reply To: Exceeding magnitude limit. Multiple bodies.
