This may indicate that something has been changed. I would suggest that you download the example again, first run it to confirm everything is ok. Then modify the structure. Before running, reselect the modes and make sure they have updated. Other than the above suggestion, the forum may not be able to help further. If you have premium support, please send us email with simulation file attached.
