Thanks Swathi.
@agupta, as per above suggestion you may check for paramterization of SYS 2 if other systems generated prior or later are required or not. Based on that you can take a call. If you are coupling from one system to another as branch tree and each system is required in module then you may have to retain all.
Thanks
