Jim Day
So you're concerned about the difference between the pressure loading on the surface of the ambient layer and the pressure seen in the ambient element.
As an experiment, remove the *LOAD_BLAST commands and apply the pressure from blstfor directly using *LOAD_SEGMENT_SET. Do you get the same response?
