Zero heat flux in a wall means insulation not zero heat transfer. When heat flux is zero at a boundary it means that conduction heat transfer is zero but convection heat transfer is not necessarily zero because while there is temperature difference between wall and fluid convection heat transfer occurs but heat transfer in form of conduction through the wall from outside into inside or inside onto outside is zero. This is the meaning of zero heat flux.
