Ashish Khemka
Hi Filip,
SIG$SEGV is short for signal segment violation. Technically, it is described as an incorrect use of pointer or a buffer overflow (memory problems). It is a bug, whenever it happens, but it is difficult to relate the cause to any one particular issue. Based on previous call records, it has happened in the past with distributed solver and rezoning, but is not limited to these applications. Using GPU may be causing it. The two errors indicated apart from segment violation are also related to GPU.
Ashish Khemka
