December 30, 2022 at 6:31 pm
Hi HuiLiu.
As far as I know, when force density is imported from a transient analysis in Maxwell into Mechanical, it is necessary to specify a specific time to import the force value at that time. That is, it is not possible to import force changes (in terms of time) in the entire analysis time, as the curve shows.
So, the only way I had was to approximate the graph linearly. In this way, the times related to the extremum points can be determined for importing the force density at them. Next, if the ramp can be correctly determined to load the table values in time steps, the linearized graph will be obtained.
