Hello Sa-aadat,
Why do you want to import a .k file into Ansys Workbench? Do you want to build a new model based on an existing model?
I don't think we can import a .k file in WB 2022R2 on Linux. This can be done on Windows (see below). Note that only the LS-DYNA solver is officially supported at 2022R2 and not the user interface on Linux:
https://www.ansys.com/content/dam/it-solutions/platform-support/ansys-2022r2-platform-support-by-application-product.pdf
You can build an LS-DYNA model in WB in Linux using the LS-DYNA system. If you double click on the Model branch, it will launch the Mechanical interface:
In Mechanical, you can write the input file:
But, because the UI is not fully supported at 2022R2 on Linux, you might see some crashes. We recommend using a Windows machine with WB LS-DYNA.
If you want to import the .k file in WB, you will have to find a Windows machine, install WB 2022R2 and import the .k file using an External Model system as follows:
If you want to run a .k file with the LS-DYNA solver on Linux, you don't need to import the .k file in Workbench. You can use command lines to run LS-DYNA directly in the Linux terminal. You will find more information here:
https://forum.ansys.com/forums/topic/run-ls-dyna-in-hpc/
You can download the LS-DYNA solver for Linux here;
lsdyna.ansys.com
Let me know how it goes.
Reno.
