Happy New Year,
@Dave Looman, thanks for your answer.
I define in the load loop a component, which includes the currently active external nodes of the extruded material:
cm,external,node
I’m struggling still with the esurf command:
ESURF, XNODE
, Tlab
, Shape
Generates elements overlaid on the free faces of selected nodes.
The XNODE definition is not really clear to me.
With your suggestion, I would script the radiation as follows:
*do,…
Load
/prep7
/GOPR
*get,nmax,etyp,,num,max
eakt=nmax+1
*get,mmax,node,,num,max
nakt=mmax+1
et,eakt,surf152 !Surf152 Elements
keyopt,eakt,5,1 !Extra nodes
keyopt,eakt,9,1 !Radiation with form factor real constant
keyopt,eakt,11,1 !Nodes DOF-TTOP
r,eakt,1,5.8e-8 !Stefan Boltzman constant
mp,emis,eakt,0.5 !Emissivity coefficient
mat,eakt !Material assignment
type,eakt !Type assignment
real,eakt
cmsel,s,external
esurf,nakt
d,nakt,temp,tamb
alls
toffst,273
/solu
nropt,full
Load or something else
*enddo
Is the radiation with this code applied or is something else necessary in the load stage(/solu) after leaving the /prep7 ?
Greetings
John M.
