Have you considered using Execute commands for your requirement? You can input the equivalent TUI command for reading your journal file and execute it post calclation. And refer to this section for numbering the files (to avoid overwriting) that are written: 3.1.7. Automatic Numbering of Files
New Post - Reply To: setting DPM results as an output prameter in Workbench/fluent prameter analysis
