January 2, 2023 at 9:27 am
This error can indicate that a fault happened during the installation process or a graphical driver issue. Do you know if the installer has been downloaded from our site? What happens if you run CFX-Pre in standalone? Does it work? If it does work in standalone could you please go to an explorer Window type down %APPDATA% on the path and then go to the folder Ansys. Please search for the folder v201 (say you are using v201) and rename it to v201.old. Then please close the workbench and re-try. Also, try updating the graphics driver.
Ashish Khemka
